Optimization S parameters
Hello,
I have the following problem.
I would have to vary the variable epsr and tan_delta, respectively the electric and tangent permittivity of loss of the dielectric that I have in the rectangular guide, so that the scattering parameters are equal to measurements made with the VNA.
How can I set everything up with the optimization search?
I set the problem in the following way but by launching the simulation I had warnings.
Recapitulate the problem.
I have measurements made with the VNA of the scattering parameters S11 and S21 with a configuration of a rectangular waveguide with a dielectric inside.
I intend to quantify the relative dielectric constant and its loss tangent.
So to get the latter I started by determining an initial value for the two, and then configuring an 'Add Search' where I configured two masks (one relating to the magnitude of S11 and the other relating to the magnitude of S21).
In the 'Goals' I defined two goals: the two scattering parameters must be the same as the two masks I defined.
In the 'Parameters' instead I made the two variables vary: epsr and tan_delta.
I wanted to know:
- Is it right how I set the problem?
I put the configuration files back because I changed the model
Hi John1989
I don't see much wrong with your setup.
But are you sure you want to vary the permittivity from zero onwards? Does not sound realistic. Maybe rather from 1 and up? Or are you trying something in terms of metamaterials?
Also the tan delta varying up to maximum 1 is very high?
What warnings did you receive?
To make the solution faster, you can set the horizontal plane of symmetry to electric.
