Midsurfacing final editing
Altair Forum User
Altair Forum User
Altair Employee
edited November 2020 in Community Q&A
Hi,
I am trying the mid surfacing a component that is already in the online learning library. I am using Hypermesh 14.0. The .pdf file for that component is for HyperMesh 13.0. I am having trouble with moving a rib to a new location. Can you please tell me how I can do it? I am attaching the file and the image file of the problem.
Thank you,
Tanmay Ingle
Welcome!
Answers
  • Sanjay Nainani_20973
    Sanjay Nainani_20973 New Altair Community Member
    edited February 2018
    Hello,
    Can you please tell me which exercise you are doing in the learning library.
    Thankyou
  • Altair Forum User
    Altair Forum User
    Altair Employee
    It is in learning and certification tab. Mid Surfacing. I have the hypermesh file of the model. I have extracted the mid surface and I am trying to edit it. I want to move the rib like part on the yellow line but there seems to be some problem with selecting a target when there is no point or node over there? According to pdf file I just have to click and hold to select the line and then click again to select a target but that is not happening. I am attaching the pdf and model file. Refer 9. to 20. on pages 5,6,7.
    Hello,
    I would suggest you to update to HyperWorks 2017 Student Edition and do the HyperMesh 2017 certification exam as it is the current version available and the HyperMesh 13.0 Certification exam will not be available in some time.
    Thankyou
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Can we treat this as a HyperMesh problem and try to solve it? I am using HyperMesh 14.0 which I think is quite capable to handle these kind of stuffs and maybe I don't know how? I just want to the rib's bottom edge moved to the yellow line? Maybe you can refer my problem to a more experience professional?
    Hello,
    I am working on this and will get back to you as soon as possible.
    Thankyou
    Hello,
    This feature of selecting a fixed point on the fly by selecting a line is not available from 14.0.
    For this exercise there is a workaround.
    First go to 'Geom>>point edit' and create a point on the line to which you want to shift the surface to.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.1fe3e5e055124201fb27ddb8daabc941.png
    Then go to 'Geom>>midsurface>>final edit tools>>assign target'
    Select the triangular surface to move, then select the both points.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.63ffe3184bd5507d40f0bc1cc06f5771.png
    Hope this helps.
    Thankyou
Welcome!
Welcome!
