Composite twill weave ply how to create.
1 - 6 of
61
Hi Ashok,
For woven fabric you may consider it as a bi-directional ply.
The material properties is what defines whether the ply is a uni-directional or bi-directional.
Fabric is considered as 1 single ply while its bi-directional nature is incorporated in the material properties. If E1 and E2 are equal or almost equal in material card then the ply is asummed bi-directional fabric and the reference material orientation is the longitudinal direction (or Major direction/load direction).
You can assume two plies with 0° and 90° orientation,assign thickness of half to each.
