Composite twill weave ply how to create.
Hi all,
Can any one tell me how to create the composite twill weave single ply. as shown in the attached image. which options can i use for creating this type of ply. please let me know which option can be used for it.
Thanks & regards.
Ashok.
You can assume two plies with 0° and 90° orientation,assign thickness of half to each.
0 -
hi chaithanya, thanks for reply. i was worried whether that model will give the same or at-lease same mechanical properties, like strength, stiffness, etc.
0 -
Hi Ashok,
For woven fabric you may consider it as a bi-directional ply.
The material properties is what defines whether the ply is a uni-directional or bi-directional.
Fabric is considered as 1 single ply while its bi-directional nature is incorporated in the material properties. If E1 and E2 are equal or almost equal in material card then the ply is asummed bi-directional fabric and the reference material orientation is the longitudinal direction (or Major direction/load direction).
0 -
Hi Prakash,
Is there any thing wrong if we assume two plies with 0° and 90° orientation,assign thickness of half to each,in this case material properties will be defined as unidirectional ply.
what makes the difference?
0 -
Yes,the image attachment is a special case-Zone based modelling where 90°plies may not be present.Also,we can change the PCOMPG card,and set THETA to 90°
But we do define plies with 90° right. In fact its user's will to define the angle.
