How to link variables with abaqus slover?
Hi, I'm using abaqus as a slover. There are two models which should be optimize synchronously, so some variables were linked.
Acitive       Label         Varname                 Expression
1                 com1_1    m_1_varname_1
1                 com2_1    m_2_varname_1    m_1_varname_1
But when the 'evaluate' was conducted, there are errors occured:
13 Error : Scalar value expected for ( com2_1 (m_2_varname_1) )
14 Warning: Could not set the value of variable ( com2_1 (m_2_varname_1) ) in model ( Model 2 (m_2) )
I'm wondering whether the slover script didn't support the two models link variables?
#!/usr/bin/env python
''' Example script to run abaqus
# import statements
import os
import platform
import subprocess
import sys
# user edits-------------------------------------------------------------------
# set abaqus path use forward slashes (/)
abaqus_exe = 'C:/SIMULIA/Abaqus/Commands/abq6121.bat'
# set abaqus arguments
abaqus_arguments = 'job=' + sys.argv[1] + ' ' + 'memory=20000Mb cpus=36 interactive'
# set log file name
logFile = 'logFile.txt'
# open log file
f = open('logFile.txt', 'w')
# get environment information
plat = platform.system()
hst_altair_home = ''
strEnvVal = os.getenv('HST_ALTAIR_HOME')
if strEnvVal:
    hst_altair_home = strEnvVal
else:
    f.write('%EXA_xx-e-env, Environment variable not defined ( HST_ALTAIR_HOME )')
abaqus_exe = os.path.normpath(abaqus_exe)
lstCommands = [abaqus_exe, abaqus_arguments]
# echo log information
f.write('platform: ' + plat + '\n')
f.write('hst_altair_home: ' + hst_altair_home + '\n')
f.write('abaqus command: ' + abaqus_exe + '\n')
#execute the command
f.write('Running the command:\n' + ' '.join(lstCommands) + '\n')
p1 = subprocess.Popen(' '.join(lstCommands), stdout=subprocess.PIPE , stderr=subprocess.PIPE)
# log the standard out and error
f.write('\nStandard out' + '\n' + p1.communicate()[0] + '\n')
f.write('\nStandard error' + '\n' + p1.communicate()[1] + '\n')
# close log file
f.close()
# End of file:
1 - 8 of 81
