🎉Community Raffle - Win $25
Join and Win
Error: [fmi2GetContinuousStates]: Simulation terminated at t=0.0000000000000000e+00: error running events
arnigaberUser: "arnigaber"
Altair Community Member
Updated by arnigaber
Hello to all, in my first model i want to simulate a dumper using a cylinder with orifice in the line to the tank.
I've tried different configuration but every time appears this type of error and i don't understand what it mean.
Is there someone that can help me uderstand this error? What i have to change?
Thanks in advance!
Arnigaber
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.fe05a0392d6cf8a23c70827cbf2affab.png
1 - 6 of 61
    L MorettiUser: "L Moretti"
    New Altair Community Member
    Updated by L Moretti
    Hello Arnigaber,
    can you share your model file?
    Lorenzo
    RoKetUser: "RoKet"
    Altair Employee
    Updated by RoKet
    Hi Arbigaber,
    It's a problem of initial values. In Modelica mechanics length of elements in a row are added. with basic parameters, the initial position of v-source is 0 m, length of left rod 0,4 m. Position of fixed is 0 m => relative stroke of cylinder is 0,4 m (in right end stop). Now you have to move either v-source to the left or fixed to the right to move piston into middle of the cylinder.
    My demo model has a fixed position of 0,2 m.
    OP
    Hi RoKet, with your help I managed to run the simulation.
    Thank you very much!
    BrettLUser: "BrettL"
    Updated by BrettL
    Hi guys,
    I'm having a similar problem with a model I'm trying to set up and I'm hoping I can get some help.
    I've got a cylinder being driven by a position source, but when I run I get the same error. I've tried changing the fixed position as per RoKet's post above but this doesn't seem to work on this model.
    I eventually need to add an accumulator onto the piston side of the cylinder, but need to get this simple model working first!
    Could someone have a look at this model and let me know what I'm doing wrong here?
    Many thanks!
    RoKetUser: "RoKet"
    Altair Employee
    Updated by RoKet
    Hi BrettL,
    It's the same solution. You have to consider all positions and length. In Modelica (and the hydraulics library) positions are calculated as a row of points and lengths. In your case the row starts with the fixed element at 0 m. The cylinder has a minimum length of 0.4 m, so the rod tip has a minimum position of 0.4 m, a maximum position of 0.8 m (stroke of 0.4 m).
    The range of position source has to be in the given limits of the cylinder, I've shifted the offset to 0.6 m (0.4 m length and initial stroke of 0.2 m). In addition I've set all initial values to the right value (cylinder stroke, s_ref, ToModelica. It's not always necessary, but helps the solver to find the correct initial state.
    RoKet
    Updated by BrettL
    Hey RoKet,
    Thanks a lot for that... your explanation makes more sense to me now. Your model works as I'd intended, so really appreciate your help.
    Now to work on the accumulator... :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Cheers, Brett.
