🎉Community Raffle - Win $25
Join and Win
Multi plane waves simulation
ZakariaUser: "Zakaria"
Altair Community Member
Updated by Zakaria
First, thanks a lot for your continuous great help. I need to excite my structure by two plane waves simultaneously each of different frequency . is there any way to do this? hint: I don't want to use superposition theory.
Thanks.
1 - 3 of 31
    JIFUser: "JIF"
    Altair Employee
    Updated by JIF
    Hello Mohamed,
    You can simply create two (or any number of) plane wave sources. FEKO supports this and always has. Did you try this or is there are reason why you think this does not work he way you want or think it should?
    OP
    Updated by Zakaria
    Hi JIFWhat I want to do is to select a different frequency for each plane wave for the attached file. I can only select one frequency which will be automatically added to all the plane waves.
    Thanks
    MelUser: "Mel"
    Altair Employee
    Updated by Mel
    Hi Mohamed
    You cannot have two plane waves with two frequencies excited at the same time in FEKO.
    You can define 1 plane wave with 1 frequency at a time, and in a 2nd StandardConfiguration, you can define another plane wave with a different frequency, and so forth. But as stated, these will be solved separately.
