🎉Community Raffle - Win $25
Join and Win
Script to create center line for shape tube (Same radius)
User: "alpha_21885"
Altair Community Member
Updated by alpha_21885
Hello everyone,
I am trying to create macro  to extract center lines of surface tube (then create 1D elements) but it works only for simple shape.
For the a bit complex shape, the center lines are not smooth at bending area.
Appreciate very much anyone can give some suggestion for this.
1 - 2 of 21
    User: "tinh"
    Updated by tinh
    Hello
    I made it but rarely use
    Suggestion for you is not to use F9 create mid lines, you should create mid line by line drag a radial line along wire path
    line drag does not create a line but create a surf whose one edge is mid line
    in my macro I generate a thin surf (actually zero width) so it is a mid line!
    my macro:
    User: "maysam"
    Updated by maysam
    Hello
    my macro:
    Hi tinh,
    You referred to a script in this response but I only see a YT video.
    Could you please direct me to the script?
    Thanks!
