Script to create center line for shape tube (Same radius)
Hello everyone,
I am trying to create macro to extract center lines of surface tube (then create 1D elements) but it works only for simple shape.
For the a bit complex shape, the center lines are not smooth at bending area.
Appreciate very much anyone can give some suggestion for this.
Hello
I made it but rarely use
Suggestion for you is not to use F9 create mid lines, you should create mid line by line drag a radial line along wire path
line drag does not create a line but create a surf whose one edge is mid line
in my macro I generate a thin surf (actually zero width) so it is a mid line!
my macro:
Hi tinh,
You referred to a script in this response but I only see a YT video.
Could you please direct me to the script?
Thanks!
Hello
my macro:
