Importing results from Hyperview to Hypermesh
I am trying to take results from one step of a solver from Hyperview and import that step into Hypermesh in order to run a new analysis with the results of the previous simulation. Is this possible?
If not is there a way to delay a thermal load until a time step has been met in a model?
Any assistance would be great!
Thanks
1 - 1 of
11
If you are using Optistruct for your analysis, you could use subcases to get what you are looking for I think (i.e. perform sequential steps in the solver) rather than load in results
There is an example in help OS-E: 0020 Inline-4 Engine Head
That pretensions bolts for a cylinder head then applies a thermal load
