How to specify the gravity load in Hypermesh (solver Optistruct)
we have created load collectors and defined card image as Gravity where we provided g value as 9810 mm/sec^2 and direction in Y axis.
Also defined load steps.( through support 1= Gravity collector no) while solvning this we are getting the following error.
WARNING: GRAV SID 3 is not referenced by Case Control.
ERROR # 23 FROM SUBROUTINE renum2
SID 3 is referenced by SUPORT1, but is not referenced by any bulk data.
kindly provide your valuable suggestion for the same.
1 - 4 of
41
Delete existing loadstep & recreate it and you should be all set.
