1 - 10 of
101
there are multiple ways through which you can achieve good mesh using ruled command.I believe you would have selected end mutiple edges along the length of box.edge to edge would also work fine.
hi, Rahul
Thanks for your answering. I did this as the picture below shows. I don't know why. Could you tell me where am I wrong?
thank you very much
But I tried to remove fixed point, the suppress and release commands are not work. How could I change the fixed point position? thanks!
