🎉Community Raffle - Win $25
Join and Win
ruled panel
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dear all
      I want to mesh a box use ruled panel. But when I selected two edges of the box. It creats a mesh that crosses itself, resembling a bow tie. whether I checked the auto reverse, it dosn't work. Could you help me? Thanks!<?xml version="1.0" encoding="UTF-8"?>a.jpg
1 - 10 of 101
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    there are multiple ways through which you can achieve good mesh using ruled command.I believe you would have selected end mutiple edges along the length of box.edge to edge would also work fine.
    Altair Employee
    OP
    hi, Rahul
         Thanks for your answering. I did this as the picture below shows. I don't know why. Could you tell me where am I wrong?
    Could you share hm file for same?
    User: "tinh"
    Updated by tinh
    It's because fix points on 2 lines are not parallel to box axis
    In your case, use 2d>drag is better
    Altair Employee
    OP
    Altair Employee
    OP
    thanks for your answering
    I also found this, but the fix points could not be suppressed or released. What should I do, if I want to make them parallel?
    I see free edges and toggled line.
    Specially in your case fixed was creating problem. At both end fixed points was not at same location.After creating fixed point at same location ruled command works fine.
    See attached screenshot.
    Altair Employee
    OP
    thank you very much
    But I tried to remove fixed point, the suppress and release commands are not work. How could I change the fixed point position? thanks!
    User: "tinh"
    Updated by tinh
    You cannot remove fixed point if it is unique on the line, add new fixed point then remove the old one (F11> add/remove point)
    Altair Employee
    OP
    Thank you very much!
