🎉Community Raffle - Win $25
Join and Win
H3D Question
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
Is it possible to get more than two data contour in one .h3d file?
After import h3d file into HV the most I can get is displacement and one other contour.
Is there any possibility to export to one h3d file for example stress, displacement and strain?
1 - 3 of 31
    Altair Employee
    OP
    Hi,
    as i know it is not possible from HV.
    But a much better way is to use HVTrans.
    In HV V12.0 look at Menu Applications->Tools->HVTrans, or use the link in start menu.
    In HVTrans you can select what you want...
    Regards,
    Mario
    Altair Employee
    OP
    Thanks Mario,
    HVTrans solves my problem partly.
    But it names all the components by its ID.
    Is it possible to get my assembly hierarchy after reading exported .h3d file into hyperView?
    Altair Employee
    OP
    Hello,
    try to load the original solution deck as model HV->Load model->your deck (e.g. bdf, fem, key...) and the h3d as result only HV->Load result.
    Or try to use the Menu point Tools->Extract Solver Deck Assemblies.
    But normally you get the assembly hierarchy into the h3d file. You can change the source of model file in HVTrans.
    Be sure there is a hook in 'Include model with translated results'. Try to change the source to 'From input deck' and select the right one.
    Regards,
    Mario
