Altair RISE
Nominate Yourself Now!
Bind Mouse button on tree widget - hwtk::treectrl
User: "vipin_22401"
Altair Community Member
Updated by vipin_22401
Hi all,
Is it possible to bind mouse button operations on hwtk treectrl widget?
For example I have created a tree like below, when i click on any item, it should act as a button and execute some command.
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    Hi Vipin
    did you try setting a callback for option -selectcommand when creating the treectrl ?
    when you select some thing it will invoke -selectcommand
    User: "vipin_22401"
    OP
    Hi @tinh
    I added -selectcommand as you said.
    Anything I select in the tree it is running that command, but how do I assign different script/command for each of the buttons?
    User: "tinh"
    Updated by tinh
    Hi Vipin
    example
    set t [hwtk::treectrl $treewnd -selectcommand 'p_AtSelected %W']
    proc p_AtSelected t {
         set items [$t select]
         #you may select more than 1 item so pls handle it
          foreach item $items {
               set text [$t item text $item 0]
               switch -- $text {
                     button1 {
                      button2 {
    User: "vipin_22401"
    OP
    Hey tinh,
    Thanks a lot for the help. It is working perfectly!!
    I Added -selectmode single, so multiple selection solved :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    can u share me this macros
