Radioss Section force from connect element
alessandro_22288
alessandro_22288 Altair Community Member
edited November 2020 in Community Q&A
I have a simple model with cohesive element in lap shear test i put a section on a midlle oh hexa elment
if i plot force from rbo that pull the specimen i get some data , therefore in i plot th/section all data is 0.
Does Radioss not support section made with cohesive element?
tks.
Answers
  • Rogerio Nakano_21179
    Rogerio Nakano_21179 New Altair Community Member
    edited January 2021
    Hi
    The connect element has only three "strain" components - traction/compression in normal (Z) direction (thickness direction) and both transverse shears XZ and YZ. Actually, in-plane shear, as well as lateral tractions/compressions does not give any resistance forces. It's a pure "connection" element and is not intended to be used in independent way.
    If you need to check /SECT forces, i suggest create section on the one of specimens parts.
    Regards
  • Dhanasharee Jadhav_20562
    Dhanasharee Jadhav_20562 New Altair Community Member
    Hi,
    Yes, you can create a section on any specimens and check /SECT forces.
    Regards,
    Dhanasharee Jadhav
Welcome!
Welcome!
