🎉Community Raffle - Win $25
Join and Win
How to get the component id
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
 My objective was to write a program to select the components from the file and i want to print the ID's of the component which i have selected in order.
when i try to print those i am getting the ID's in ascending order..
I want those ID's in the order i have selected..
I selected the components using this option.
*createmarkpanel comps 1 'Select Components//s'
set compList [hm_getmark comps 0]
Thanks in Advance.
Karthikeyan
1 - 8 of 81
    Altair Employee
    OP
    Hello,
    try the following...
    *createmarkpanel components 1 'Select components ...'
    set compList [hm_getmark components 1]
    hm_markclear components 1
    foreach compID $compList {
        set compName [hm_getcollectorname comp $compID]
          tk_messageBox -message 'CompName (CompID): $compName ($compID)'
    Regards,
    Mario
    Altair Employee
    OP
    Thanks for the reply..
    Example:
    Comp_1 (1234)
    Comp_2 (2345)
    Comp_3 (3456)
    But still if i select the component in a order like Comp_2, Comp_3 & Comp 1.. Still it is showing in the ascending order like Comp_1,Comp_2 & Comp_3..
    It should show like Comp_2, Comp_3 & Comp 1..
    User: "tinh"
    Altair Community Member
    Updated by tinh
    hi,
    using *createlistpanel instead of *createmarkpanel will return an ordered list
    Altair Employee
    OP
    We can use *createlistpanel only for elems, laminates, lines, nodes and surfs. But not Components. I have checked that also..
    Regards
    Karthikeyan
    User: "tinh"
    Updated by tinh
    yes, that's right. I hope altairians will make it possible soon for comps
    you can repeat 'hm_getmark' to monitor changing in the mark and can get the comp list as in order
    for example
    set complist {}
    set repeat_on 1
    repeat_hm_getmark
    *createmarkpanel comps 1 'select comps:'
    *clearmark comps 1
    set repeat_on 0
    tk_messageBox -message $complist
    this is minimum example of proc 'repeat_hm_getmark'
    proc repeat_hm_getmark {} {
      foreach compid [hm_getmark comps 1] {
        if {[lsearch $::complist $compid]==-1} {lappend ::complist $compid}
      if {$::repeat_on} {after 100 repeat_hm_getmark}
    Altair Employee
    OP
    Thanks for the Reply!!!
    I am new to the Tcl scripting and i know how to convert from cmf to tcl and  to use some loops to do the repeated tasks..
    i came up with a different idea, like get the components one by one and print it on a file.
    set fileName 'component_id.txt'
    set fileId [open $fileName 'a+']
    set i 0
    set length 5
    while {$i < $length} {
    *createmarkpanel comps 1 'Select One Component'
    set compList [hm_getmark comps 1]
    set id [lindex $compList 0]
    puts -nonewline $fileId '$id'
    puts -nonewline $fileId ' '
    set i [expr {$i + 1}]
    close $fileId
    But, the problem with this is it will get only 5 components from the user.. Is there anyway doing like getting the input till the user press a key, For Example 'ESC'...If he presses ESC it should come out of the loop and the file should be written with the given inputs..
    User: "tinh"
    Updated by tinh
    yes, ofcourse you can do it
    if you press esc mean you do not select any comp more
    so hm_getmark comps 1  will return '' to complist
    so you just check complist:
    if {[llength $compList]==0} {break}
    break will terminate the loop
    Altair Employee
    OP
    Thanks!!!. It worked perfectly...
