Altair RISE
Nominate Yourself Now!
Can't Boolean-Combine PolyNURBSFit and non-design space parts
User: "simonebellini simonebellini"
Altair Community Member
Updated by unknown
Hi everyone,
I'm currently larning how to use Inspire to perform topology opimizations but I can't complete one of my first jobs due to the issue explained in the title.
I performed an optimization with Stiffness target, min size=0.005m, and then used the Fit tool since the complicated geometry of the result made manually wrapping quite hard.
I tried multiple settings for Density and Break Angle, starting from default ones.
The nondesign space are hollow cylinders, I tried changing their thickness from 1 to 3 millimeters.
I always get an error saying 'Unable to complete Boolean operation' and sometimes the program keeps loading and freezes for hours until I can only force kill it from task manager.
Only hypothesis for the moment is the fact that non design parts are circular (hard to mesh?) and connect two separate regions the Fit istance is made of.
Hope you can help me since this problem is stopping me from using the Software altogether.
Thank you very much
1 - 4 of 41
    OP
    Updated by unknown
    'Up'
    User: "SouravDas0306"
    Altair Employee
    Updated by SouravDas0306
    Hi Simonebellini,
    Could you please share the file with me.
    OP
    Updated by unknown
    Hi Simonebellini,
    Hi,
    Sorry for the late answer, I had lost hope on getting an answers.
    Thank you very much for you interest, I'll send you the file in private form in a minute.
    Thank you very much indeed
    EDIT: Apparently I can't send private messages. I prefer not to post the .stmod file publicly since it contains sensitive data for my organization, where or how can I send it to you privately?
    Again, thank you very much for your support
    Altair Employee
    Hi Simonebellini,
    you can email me at sourav.das@altair.com
    Regards
    Sourav
