🎉Community Raffle - Win $25
Join and Win
getting Hyperview command file like Hypermesh
User: "sanket_patil"
Altair Community Member
Updated by sanket_patil
Can we get command file for hyperview also as we get 'command.tcl' file for hypermesh?
Regards,
Sanket
1 - 9 of 91
    User: "llyle_20499"
    New Altair Community Member
    Updated by llyle_20499
    Hi,
    Not possible, framework is totally different.
    OP
    @Livil LyleOk. So how can we do tcl scripting for hyperview then?
    Thanks,
    Sanket
    User: "Beta"
    Updated by Beta
    Hi,
    I am afraid that learning is the only way. try to use Help, HyperWorK Desktop Reference guide, you need to understand how the framework works, read and understand the hierarchy of HW and HyperView so you can find out the command you need to perform the task. Also, some examples on script exchange are very useful too
    OP
    @Toan NguyenOk. Thanks for the help :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    User: "PSiedlaczek"
    Updated by PSiedlaczek
    Is still HyperView so different from HyperMesh in way of scripting ? I cannot find documentation for scripting of this part of HyperWorks... So please If You know pint me to where can I find list of HyperView TCL commands scripts or extended help for scripting result postprocessing HyperWorks ?
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    HyperView has a different approach, using a different set of APIs.
    You can perform automations using these APIs.
    In newer versions it was included what we call HWC.
    If you enable your HWC console, you will see what is the command performed by the GUI and you can use it to build your script.
    Take a look at the Help for HyperWorks 'Record and Playback'
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Yes, it's very different. For me, there are two softwares with two different programming concept.
    User: "PSiedlaczek"
    Ok, HWC Its tracking some of commands in HV but they look as only small subset for real automated postprocessing.
    Altair Employee
    HWC is quite new in HyperView. It is a WIP. Of course there's no 100% coverage right now. They're adding more and more commands from version to version. I believe it will be the best option in a few versions.
    But if you prefer, you can go through the standard HV APIs and get whatever you want to automate, but I assure you it will take much longer.
