Altair RISE
Nominate Yourself Now!
Coupling EDEM-Fluent in Batch Commands
User: "Fatemeh Hosseini_22198"
Altair Community Member
Updated by Fatemeh Hosseini_22198
Hello Every body,
I want to couple EDEM and Fluent in batch mode.
I read the link bellow about running EDEM in batch command:
https://community.altair.com/community?id=kb_article_view&sysparm_article=KB0119775&sys_kb_id=bae616ecdb170d90e8863978f496197b&spa=1
But I couldn't find anything about coupling EDEM and Fluent, synchronize Fluent to EDEM timestep, how to continue simulation after interruption,...
Could you please guide me in this field?
Regards,
Fatemeh
1 - 6 of 61
    User: "RWood"
    Altair Employee
    Updated by RWood
    Hi Fatemeh,
    The time synchronising comes from the Fluent side, not the EDEM side. A lot of the commands specific to the coupling are available in Fluent's TUI, but I can't remember if the synch command is there as well. You would have to check in Fluent's TUI once the coupling is loaded. From memory it's under something like:
    /define/edem-coupling/
    I think...?
    Cheers,
    Richard
    OP
    Hi Fatemeh,
    I think...?
    Cheers,
    Richard
    Thanks for your answer Richard.
    I asked about it in ANSYS forum but no one knows about it and they told me you need GUI for EDEM-Fluent coupling. It is not logical. There should be a way...
    It should be a reference in EDEM or Fluent website. But I couldn't find.
    Regards,
    Fatemeh
    User: "RWood"
    Altair Employee
    Updated by RWood
    Regards,
    Fatemeh
    I don't have access to the coupling at the moment but if you look in the TUI once the coupling is loaded, there are quite a lot of settings available there. As I mentioned before, I think it's under /defined. Have you checked to see whether the synchronise setting is one of them?
    Richard
    User: "Mahdi_22303"
    Updated by Mahdi_22303
    Hi Fatemeh,
    Did you get any success with running Fluent-EDEM on a cluster without GUI? Thank you.
    OP
    Hi Fatemeh,
    Hi Mahdi,
    I didn't do that, no. I'm currently using Windows.
    I have the choice between Windows and Linux. I initially wanted to use Linux, but when I saw it was not straightforward, I returned to Windows.
    Regards,
    Fatemeh
    User: "Mahdi_22303"
    Hi Fatemeh,
    Thank you so much for the information.
