failed associavity check
Jagan
Jagan Altair Community Member
edited December 2022 in Community Q&A
I'm getting this warning during meshing.
I proceeded with yes and the mesh got generated. Now will this affect my solution or its alright?
Thank you.
Best Answer
  • acupro
    acupro
    Altair Employee
    edited December 2022 Answer ✓
    That most likely means that the surface mesh was unable to project properly to a geometric surface edge - the 'suppress' option means ignore that geometric surface edge.  Unless that is a definite 'hard' edge needing to be captured properly, you should be fine.
Answers
  • acupro
    acupro
    Altair Employee
Welcome!
Welcome!
