moments not working
1 - 3 of
31
diegoz,
Are you using solid elements?
A solid element has only 3 translational and no rotational dofs hence solids do not support moments applied to nodes.
In FEA we then need to work around the above fact.
So we create a rigid element connected to the face of the model where the moment needs to be with all its dependent nodes on the solid face and a calculated independent node.
(HyperMesh calculates the independent node by itself)
We then apply the same moment on the independent node.
Hi Diegoz,
Please make sure that you are not applying moment on temporary nodes.
