🎉Community Raffle - Win $25
Join and Win
How to export to Fluent
In what file format should I export for Fluent to read in the data. Fluent booklet says, Hypermesh Ascii format. What does this mean? Thanks.
1 - 4 of 41
    1st of all switch from Hypermesh to Engineering solutions in the user profile.. then select CFD --> click ok
    now go to File-->export FEA--> select file type as CFD; solver type Fluent; target location; click export... itzz done !!
    before exporting u should actually define all zones (inlet.outlet,interfaces,fluid domains, etc)
    good luck...
    ASCII format file is a general code format where major files are scripted. After creating the mesh in the Ansys user profile, Create an ET Type sensor for all type of elements, from 1D, 2D, & 3D panels, update all the element types from the ELEM Types option in 3D panel, and then export in to desired format.
    good luck...
    Sir how can i define all zones (inlet.outlet,interfaces,fluid domains, etc) in hypermesh
    QuyNguyenDaiUser: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Aiiiie, do you have some experience with CFD? Fluent?
