Symmetry Constrains
Hi i need to work with symmetry model for simplify the model. I've imported the geometry already simmetric on one plane. What kind of constrains do i have to use for the simmetry? Are the morph constrains?
Thank you very much
Hello I have a similar Problem.
I have a platform with 3 legs and what to optimice only a 1/6th of the model (60 Deg).
Is it in Hyperworks posible, in ANSYS there is Cyclic Symmetry.
Thanks
Hey b.o.alpers,
As to what I know it is not possible in Hyperworks. I asked for such an option a few months ago, as to do an axisymmetric analysis. The response was no, it does not exist. The minimum you can do is therefore the quarter.
Regards,
Here is a tutorial which you can refer to AxiSymmetric structures.
Hey b.o.alpers,
Regards,
It is possible, you need y-constraint in cylindrical displacement system instead of ordinary rectangular one
Hi tinh,
Thanks for your answer. How is that possible to define ? I precise that I personnaly work with Hypermesh/Radioss, and my problem of an axisymmetric simulation in implicit simulation was not solve.
Thanks,
Is this like assigning the nodes of the surface to the cylindrical coordinate system?
Because I found no option to assign a spc to a other coordinate system (other like forces, which can be assigned)
Suppose the symmetrical plane is XY. You'll work with only a half. The following constrains should be applied to all node on symmetrical plane :
