🎉Community Raffle - Win $25
Join and Win
clear mark
hello
*createmarkpanel nodes 1 'select nodes'
*duplicatemark nodes 1 0
*createlistpanel surfaces 1 'Select surface'
set targetsurf [hm_getlist surfaces 1]
set targetsurfid1 [hm_getentityvalue nodes [lindex $targetsurf 0] 'id' 0];
*markprojectnormallytosurface nodes 1 $surfaceid1
*clearmark all 1
*createlistpanel surfaces 2 'Select surface for mark node'
*createmarkpanel nodes 2 'select nodes'
if { [ catch {*surfacemarkaddnodesfixed 2 2 0.00026801845 0 } ] } {
# Handle error
*nodecleartempmark
*clearmark nodes 1
*clearmark surfaces 1
hm_setpanelproc {hm_callpanel 'automesh';}
In this program at clear mark I am not able to clear the surface stored in surfaces 1
and also not able to retrive surfaces 2 in *surfacemarkaddnodesfixed command
so have look
Thank you
1 - 11 of 111
    Hi,
    Can you try this?
    *markprojectnormallytosurface nodes 1 surfaceid1
    *clearmark all 1
    # Handle error
    *nodecleartempmark
    *clearmark nodes 1
    Just removed $ before surfaceid1
    its not working
    same error as mine 'atleast one surface must be selected'
    and I want to remove all the mark before going to select surface and nodes for   *surfacemarkaddnodesfixed this command
    tinhUser: "tinh"
    Altair Community Member
    Updated by tinh
    Hi
    You create a list of surfs, so need to use *clearlist instead of *clearmark
    below red marks are potential buggy:
    'nodes'  => should be 'surfs' ?
    '*createlistpanel' create a list of surf, but using '*surfacemarkadd...'  ==> should be '*createmarkpanel surfs 2 ...
    *clearmark all 1
    # Handle error
    *nodecleartempmark
    *clearmark nodes 1
    thank you very much
    *clearlist   worked
    in above program suppose I want to run the first part for some definite times
    then I will press a perticular key or message (till time it should repeat same set of commands)
    and then it redirects to second part is it possible??
    tinhUser: "tinh"
    Updated by tinh
    Sorry I don't understand your meaning
    *createmarkpanel surfaces 1 'Select surface for mark node'
    *createlistpanel nodes 1 'select nodes'
    *surfacemarksplitwithnodes 1 1
    so I want to run above program 4-5 times depends on situation
    then I should run following once
    set targetsurfid1 [hm_getentityvalue surfaces [lindex $targetsurf 0] 'id' 0];
    *clearmark all 1
    *clearlist surfaces 1
    *createmarkpanel surfaces 2 'Select surface for mark node'
    # Handle error
    *nodecleartempmark
    *clearmark nodes 2
    *clearmark surfaces 2
    so is it possible??
    I tried calling panel 'surface edit' instead of first part but it wont allow rest of program to continue
    tinhUser: "tinh"
    Updated by tinh
    yes, it is. i already tell you to use while loop. did you apply it?
    Yes but while loop will continue for infinitely r8??
    How can I skip that while loop after some iterations and then go to next command execution
    tinhUser: "tinh"
    Updated by tinh
    don't you see break command?
