Part + mesh geometry export
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi all
I have model geometry in IGS which I've imported to HM. In HM, I've created the mesh. Now I want to continue preprocessing in Abaqus CAE, because I need to do dynamic explicit analysis (ductile damage parameters..) and HM is lacking tools for that (or am I wrong?).
So, how can I export PART and MESH data to Abaqus so I can continue assigning properties to parts etc?
Thanks for your help
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited February 2016
    Hi,
    There are tutorials on Pre-Processing for Abaqus. If you are using commercial suite of HyperWorks, refer to the following tutorials:
  • Rahul_P1
    Rahul_P1
    Altair Employee
    You will have to export to Abaqus .inp format , from file > export , after you have set the user profile to abaqus.
    If you are using the student edition, it is not possible to interface with abaqus.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    Honestly, it is much hard for me to understand those rules.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    I can work with INPs. How can I get HM to write the geometry of the imported IGES to INP?
    The goal is to have only part geometry and mesh in the INP file. I can then continue assigning properties etc in cae..
  • Altair Forum User
    Altair Forum User
    Altair Employee
    I found a similar thread. Sounds like I'm not the only one. I will try beth02's method and report here.
Welcome!
Welcome!
