Altair RISE
Nominate Yourself Now!
Linear static analysis of plastic injection mold assembley
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi Rahul
I am doing linear static analysis on a plastic injection mold assembly. Clamping force and constraints are as following
Pressure 54 MPa (This is the maximum pressure of molten plastic when it enters the cavity) is applied on core and cavity as shown below
The problem is that, the maximum displacement is much more than what it should be in real case (It is almost 10 times more). I have used SI units and I checked material properties, units look right.
I don't know understand why I get this result. I have used bolt connection, RBE2 and also FREEZE contact to define connection between parts.
I sent you the model via your Dropbox link. I appreciate if you can spend some time and check my model and let me know what is the problem and why the maximum displacement I got is much more than the reality.Thanks a lot.
1 - 21 of 211
    Altair Employee
    OP
    Here you can see the maximum displacement if turn off components, Cavity, Top clamp plate and manifold plate in the assembly
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    just downloaded file.Will check and update you.
    what is overall weight of entire model?
    Altair Employee
    OP
    Thanks alot
    I have to contact our customer and ask that
    Altair Employee
    OP
    It should be around 8336 kg
    Is that realistic?I mean 8336 kg is too much.
    Altair Employee
    OP
    I think the weight should be fine for a injection mold machine.
    Can you share the entire .out file here, please?
    When I post process output in Hyperview i see part name Origin ins1 deform more.See attached screenshot.
    When I try to check contact between cavity block & origin ins1 in Hypermesh while reviewing contact i found contact established in some other region.
    See attached screenshot for same.Please update contact and run again.I believe that was causing unexpected max displacement.
    Altair Employee
    OP
    Hi guys
    Thank you so much for your great help. You are right I missed that contact surface. I am going to create contact there and hopefully that would work.
    Altair Employee
    OP
    I fixed the connections and now I have more realistic results
    but there are still some issues. My model is almost symmetric but I don't understand why displacement distribution is not symmetric
    The second issue is that in the core block there are two regions that have lower thickness so it is expected that cavity pressure deforms those two regions more but the results are vice versa
    it is expected to have distribution of displacement something like the follwoing pic
    In real case flashing (leakage of molten plastic) happens at these two domains and our customer thinks it is because the thickness is lower in these two region, the structure is weaker and deformation is more. but  My last result shows opposite I appreciate if you can check my model and let me know the reason. I will upload the file via your drop box link.
    Altair Employee
    OP
    Hi,
    Is the load symmetric?
    Altair Employee
    OP
    yes the load is symmetric too
    Altair Employee
    OP
    Only Manifold plate is not symmetric
    Altair Employee
    OP
    that could be one of the reasons.
    what type of contacts have you used?
    Altair Employee
    OP
    I have used Freeze contact every where since I am doing linear static analysis
    Altair Employee
    OP
    Hi
    I was wondering if you had time to check my model. I am waiting for your reply
    Altair Employee
    OP
    Hi Bita,
    I don't have access to your model. But maybe you can check your self.
    Partition the components in to 4 symmetric parts and check their mass.
    I dont feel you entire model is symmetric& toget symmetric results it is recommended to have symmetric mesh.For second query i will check and update you.
    In real how this part are connected clamp plate & ejection pin.See attahced screenshot.
    Altair Employee
    OP
    The ejection pin are cylinder pin which goes inside clamp plate' holes.They are used for alignment only.
    Altair Employee
    OP
    Is this displacement contour correct for the rigid element? It is rigid but it has moved unevenly
