Linear static analysis of plastic injection mold assembley
Hi Rahul
I am doing linear static analysis on a plastic injection mold assembly. Clamping force and constraints are as following
Pressure 54 MPa (This is the maximum pressure of molten plastic when it enters the cavity) is applied on core and cavity as shown below<?xml version="1.0" encoding="UTF-8"?>
I don't know understand why I get this result. I have used bolt connection, RBE2 and also FREEZE contact to define connection between parts.
I sent you the model via your Dropbox link. I appreciate if you can spend some time and check my model and let me know what is the problem and why the maximum displacement I got is much more than the reality.Thanks a lot.
