🎉Community Raffle - Win $25
Join and Win
begineer
NewuserUser: "Newuser"
New Altair Community Member
Updated by Newuser
Hi,
I want to simulate a transient flow for indoor in two stages. First stage is heating up process and second stage is cooling down process . My plan is to begin the second stage simulation (cooling down) using the first stage data as the initial data forthe second stage simulation,  onced air speed at a point in the domain has reached cerrtain value.
Is there a way to do this in AcuSolve?
1 - 1 of 11
    acuproUser: "acupro"
    Altair Employee
    Updated by acupro
    AcuSolve does have the restart functionality - where you can change anything but mesh node count going from the original run to the restart run.  You could probably do this in one run, using a multiplier function to change the value on heat sources (or whatever is your source of heat) during the run.
