Compression only elements
User: "lucariga"
Altair Community Member
Updated by lucariga
Hi,
I'm tring to model a semplified 2D pin element using RBE and CBAR with rotational dof release along the normal to plane.
Due to geometrical and load condition the RBE express a tension/compression on dipendent nodes.
my question is: si possible using an element (such as rbe) that is rigid in compression and not rigid (deactivated?) in traction?
