mesh and assembly
Hai, i'm new in this software. i would like to ask something, hope you can help me.
I have a design, i drew it in Catia. It consists of some part.
The design is a rack. and i want to analyze this rack if the force is loaded in this rack.
The problem is, what should i do to mesh this design in hypermesh?
Should I mesh it part by part? Or I mesh it in an assembly?
Answers
Part by part is good approach.Is your assembly consist of solid components or combination of sheet & solid?
0 -
Thanks Rahul for your help.
My assembly is consist of solid components only.
If I mesh it part by part, then how can i re-assembly it again in hypermesh?
because i want to anaylze the whole design, not only a part.
0 -
I hope you would have multiple part in assebly.If you only are going to mesh entire assembly then highlight only that specific part and mesh.
0 -
there are some contacts between parts of the rack. if i mesh the entire assembly, is it ok when i run the analysis?
because i want to analyze the entire rack, in every parts and contacts between parts.
0 -
what type of analysis you want to run & output?Share screenshot of your model.Radioss & Optistruct solver you can use for analysis.
0 -
i want to analyze the strength of this model. the deformation, displacement, stress etc. I used optistruct.
if you don't mind, would you like to tell me every step that i should do? from pre-processing until i get the result.
here are the screenshot of the model. i would like to give load in every rack. and i want to know the maximum load for this model.
there are some contacts. i really confused with it. because i want to know the strength of every components.
0 -
looks like you can model assembly using 1d,2d & 3d element.You can perform nonlinear or linear analysis using Optistruct solver.
Since you are a beginner I would recommend you to spend time for meshing and analysis tutorials and then work on your project.
0 -
Ok Rahul. thank you very much.
0 -
hai, Can i use the autocleanup before meshing body side out shell parts? Or when we use the autocleanup in Meshing, If geometry is complicated. Pls answer anybodies?
0 -
if model have geometrical error like missing surface or overlapping surface then autocleanup would be good.
how you are planning to mesh model?
I mean 1d 2d or 3d elements.
0
