spatial magnetic field source
Hi all,
does anyone tried to work with the source magnetic field in the physics slider?
I want to have a spatial constant magnetic field in a defined volume with a random material inside to check the interactions depending on the material geometry.
But after i set the type of the magnetic field source to spatial constant with 1T in one coordinat, the post processing monitor doesnt show any influences on the field inside the material.
Thanks for your help!
Hi,
In your case, you use a circuit? If it is the case this will not work. I mean you will get a wrong results.
Best regards.
