spatial magnetic field source
Altair Forum User
Altair Forum User
Altair Employee
edited May 2023 in Community Q&A
Hi all,
does anyone tried to work with the source magnetic field in the physics slider?
I want to have a spatial constant magnetic field in a defined volume with a random material inside to check the interactions depending on the material geometry.
But after i set the type of the magnetic field source to spatial constant with 1T in one coordinat, the post processing monitor doesnt show any influences on the field inside the material.
Thanks for your help!
Answers
  • asoualmi
    asoualmi
    Altair Employee
    edited February 2018
    Hi,
    In your case, you use a circuit? If it is the case this will not work. I mean you will get a wrong results.
    Best regards.
  • Wenjun Zhu
    Wenjun Zhu Altair Community Member
    edited July 2021
    have you worker out? I am trying for a circumferential magnetic field source.
Welcome!
Welcome!
