Selection of Corner Nodes
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hello,
I have a an issue in modeling. I have created a mesh with second order elements.
Now I like to create an RBE3 by selecting only the corner nodes. Is there a way to do this ?
When I select nodes with the options I found on Hypermesh, the mid nodes are also selected which I dont want.
So now I am manually selecting the corner nodes, but since the surface is a large area it takes a long time to do it manually.
It would be great if someone ca help me with a easy way.
Regards
Nagendra
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2013
    Hi Nagendra,
     i can't see any option to select corner nodes only.
    Maybe you can switch the elements to first order, select nodes and create your elements and switch back to second order (2D->order change).
    Regards,
    Mario
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2013
    Hello Mario,
    Yes, thats an option. Thank you.
    Regards
    Nagendra
Welcome!
Welcome!
