I have a an issue in modeling. I have created a mesh with second order elements.
Now I like to create an RBE3 by selecting only the corner nodes. Is there a way to do this ?
When I select nodes with the options I found on Hypermesh, the mid nodes are also selected which I dont want.
So now I am manually selecting the corner nodes, but since the surface is a large area it takes a long time to do it manually.
It would be great if someone ca help me with a easy way.
Regards
Nagendra
