parallel computing
Hi experts,
I have a hyperworks cfd problem named problem_one.hm, lets say its a simple flow over a cylindrical surface problem. I want to run multiple simulations of same single problem but with different velocitites (1 m/s, 2 m/s, 3 m/s, etc).
Is it possible for me to run the problem in parallel (all three problems at the same time in a 36 core machine with 12 cores for each problem)? I can manually copy input files and edit the inlet velocities accordingly. But do I need separate files for geometry, .hm file, mesh.dir for three different problems?
In other words, how do I run a simulation in parallel but with different condtions? Anyone has experience with that?
Thanks!
