🎉Community Raffle - Win $25
Join and Win
Mating part???
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
What is the significance of 'Mating Part' option in the 'details' panel of 'properties' dialog box of 'motion' in 'loads' as we see in the expanded tree in user process brouser?
1 - 4 of 41
    Altair Employee
    OP
    Hi,
    mating part ensure the contact with right tool as per the type of motion selected. (Double action draw/ single action draw)
    Altair Employee
    OP
    Sir,
         I'm not getting it.
    I use user process and and if in a case I want a punch to travel with ejectior pad having a blank sandwiched inbetween them, for a punch motion what should be the matting part? or do I need any?
    Altair Employee
    OP
    Sir,
         I'm not getting it.
    hi Soumitra,
    for punch the mating part will be die. hence select die as mating part.
    Altair Employee
    OP
    why die would be mating part????????
    i did'nt get you exactly.
