🎉Community Raffle - Win $25
Join and Win
thermal analysis problem
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hello. sorry for interrupting. can you help me? i am not quite familiar yet with hyperworks software. i am using hyperwork 11. i got stuck when doing the analysis for my project which involving the heat transfer @ thermal analysis. i want to analyse the heat transfer inside the motorcycle helmet which is convection heat transfer and conduction heat transfer from surrounding. i want to cr​eate temp inside helmet and outside helmet. i have try to refer to the tutorials but it not quite help bcause the tutorial is not a quite complex object such my project. i have tried many times but still not able to produce the result i want. can you show me step by step how to make thermal analysis or tips to make thermal analysis for this? this is my model.
is this model need meshing again? i make meshing using 2d but still got 4 failure for the model. however i got stuck at creating inside temperature and outside temperature. how can i solve this? anyone can help?
1 - 11 of 111
    Altair Employee
    OP
    Hi Syamil.
    If I have understood it correct, you want to model an intial condition inside the helmet and ambient temperature as the outside temperature.
    Go to Analysis>> Temperature and create temperature for inside. Now, create a DLOAD card and refer the TLOAD1 in this DLOAD.
    For the rest you can give through TEMPD. TEMPD is available as a load collector.
    When creating loadstep for heat transfer, Refer TEMPD card for IC and , you can refer to DLOAD created in above step in the subcase directly.
    Altair Employee
    OP
    Hi Prakash,
    Thank you for your help. I will try to do the analysis first based on what you told.
    Altair Employee
    OP
    Syamil,
    The analysis type will be transient. So you need temperature data varying with time. Please keep a note of this.
    Altair Employee
    OP
    Hi Prakash,
    Can i know what is DLOAD card, TLOAD1  and where is it?
    Altair Employee
    OP
    Hi Prakash,
    I have stuck at create DLOAD. which panel should i choose to create and i cannot make TEMPD...
    Altair Employee
    OP
    It said no nodes found in the model... what should i do?
    Altair Employee
    OP
    Hi,
    Please refer to the tutorial OS-1090: Linear Transient Heat Transfer Analysis of an Extended Surface Heat Transfer Fin to start with.
    Altair Employee
    OP
    Hi,
    anyone have the OS-1090 video for the Linear Transient Heat Transfer Analysis of an Extended Surface Heat Transfer Fin. i dont have it...
    Altair Employee
    OP
    cannot download from altair bcause account still in approval.
    Altair Employee
    OP
    really need to see the video @ can i have some assistance regarding on what to do?
    Altair Employee
    OP
    Hi Syamil92,
    There is no video available as of now.
    Please refer to the tutorial for more information.
