Optistruct Error '76
Dear community,
I am working on an exercise for university and this is my first time constructing and analyzing in Hyperworks. Unfortunately, I get an error when I want to analyze my construct. The error code tells me this:
*** ERROR # 78 ***
PLSOLID data can only reference MATHE data.
This error is for MID # 1,
referenced by PLSOLID # 1.
I would really appreciate it if you are able to get me on the right track. I am really unsure how I can solve this issue.
I also added the FM file and the exercise as an attachment.
Best regards and thank you very much in advance,
Felix
1 - 3 of
31
Hello Felix,
Use PSOLID instead of PLSOLID which is used for hyperelastic material (MATHE).
You also need either to delete the PSHELL elements or to assign a PSHELL property to them.
Use VALIDATE>FREE EDGES>equivalent nodes to fix the free nodes.
Finally, define a subcase and apply any load (you can use a rbe2 element in the hole to apply it).
PS: I'm attaching a model just as an example, adjust it at your convenience.
The model has first-order and second-order elements at the same component. Be sure you are using elements well-connected (you could use only first-order elements, for example).
The mesh is unconnected as shown in the picture, you should fix it as well.
Thank you,
