No Engine File in Hyperworks v13.0 student edition
Hi all, i was learning Radioss using Hyperworks student edition v13.0. While solving the title 'RD-3500 Tensile Test Setup using HyperMesh' using the file 'tensile_test_hm' i happened to find that there's no 'engine file' located in the utility menu. Below is the image showing absent of Engine file option in utility menu. First image is the student edition where there is no Engine file and second image has been taken from tutorial where engine file is present.
1 - 5 of
51
Starting from 13.0 version we have removed engine card utility.Same you can define via control card Engine parameters.
