Hello,
I'm trying to run a dummy seat crash similar to tutorial RD-3150 except my simulation keeps crashing because of this error. I'm using Radioss Block 140, and FOAM_PLAS is the material being used.
Basically what is happening is the seat foam starts imploding and then rapidly explodes. Clearly, the seat foam is getting deformed so severely that the it ends up becoming a negative volume. It may also be important to note that this failure does not always occur, only sometimes.
I'm wondering why this didn't occur in the tutorial and also wondering how I can fix it?
Should I assign a failure criterion to the foam elements so they start getting deleted at higher strains?
I've seen similar forum posts on this error and the solution has been to change strain formulation settings but I am not too familiar with these.
Thanks.
