tangent coordinate..
Hello Everyone!
Recently I have come across with an HM API i.e. '*tangentbetweennodeandline'.
Syntax for the HM API --- *tangentbetweennodeandline is 'node id line id checkpoints lineselected'
for using this command it asks us NODE id and a LINE id, also the checkpoint where I generally use '20' for better accuracy.
But the only thing which I don't get is what to use in 'lineselected'
When I use the same option through GUI I was able to select the required line, but when I want to use the above mentioned HM API it is requiring me to hardcode the line number beforehand which I'm not sure of the correct line.
So I would be glad if anyone can help me with this specific problem of selection of lineselected.
Thanks in advance.
Regards,
Brahmadev.
