Creating adhesive brick elements
Hello,
I need a help with procedure please.?
I am able to create the adhesive brick elements mesh using optistruct (3D - connectors - area - 'constant thickness' as Hexathickness - type 'adhesives' ) in student version (Hypermesh 2019) (as in the image).
But in Radioss ( Block format 140) (Hypermesh 2017.2), the same process is not working. While using the same procedure, I get the surface connector (as below) without thickness (even while creating through: 3D - connectors - area - 'adhesive(contact)' as type). But I would like to create the brick elements.
Also, I would like to do hexa positioning it with 'mid thickness' option and I couldn't change the 'shell gap' option to the 'mid thickness' with the drop down (as shown in the highlighted below).
Could anyone please tell me if it is possible and also how to create it in the Radioss.?
Thanks in advance!
Thanks for the tutorial. /emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' /> It was helpful.
Would it be possible to create the same if the upper and lower plate shell elements are of different size(like elem size in upper plate = 20mm and in lower plate = 6mm? Because when I try, the connector is realized at one plate and not in the other plate.
Tied contacts are created automatically (along with materials, properties,...) when creating connectors with post script (see the end of the previously shared tutorial).
Type 2 tied contact:
Hi Simon? I would be very happy if you couls send the *.hm file or *.fem file. Thank you very muchHi,
I am able to create an area connector of type adhesive (contact) in Radioss (Hyperworks 2019.1 in Block format 140 user profile). The red rectangle indicates the connector realization failed for some reason (usually due to inappropriate tolerance).
Hi,
