Hypermesh 2017.2 Node picking problem
Updated by Altair Forum User
Hi,
I have been struggling to pick nodes from the screen, specially when the node I want to pick is the independent (centre) node of an RBE (spider) with lots of dependant nodes. This did not use to be a problem in older versions. Do other people have this issue and is there any way around this problem? I have tried to adjust the 'node tol', 'pick tol' on the mesh option but it did not help.
Thanks
1 - 3 of
31
Thanks but by RBE I meant an RBE2 or RBE3, not rigid body.
Hi afura
You can identify the independent node id of a rigid by using card edit option. click on card edit > select the rigid element and set the options as per image > click edit and then you can see the independent node of rigid.
Then for a further selection of this node you can select using node id
