🎉Community Raffle - Win $25
Join and Win
What's the difference among different midsurface extration method?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all,
In hypermesh, there are different methods to extrating midsurface, like skin offset, offset, offset+planes and offset+planes+sweeps. What's the difference among this methods and how to judge which method is proper for a given geometry? Is there any detail reference document about this? Thank you.
<?xml version="1.0" encoding="UTF-8"?>1414411302_20181211211316.thumb.png.48122fabed058a20c0fde1a6d16aba3d.png
Roy
1 - 3 of 31
    User: "Pranav Hari"
    Altair Community Member
    Updated by Pranav Hari
    Hi Roy Duan
    skin offset: Generates a midsurface by duplicating and offsetting the inner skin surfaces and assigning them a constant thickness
    offset:  Creates pieces of the middle surface by offsetting the model’s surface towards the middle. This is the traditional approach for midsurfacing in HyperMesh
    offset+planes: uses a midsurface algorithm to identify the planes in the model where a piece of plane can be used as a middle surface
    offset +planes+sweeps: It uses a midsurface algorithm to identify the places where a piece of plane or a piece of a sweep surface can be used as a middle surface. A middle surface is constructed at the remaining places in the model, for example the places where planar or sweep surface pieces cannot be used as a middle surface, by the same algorithm as in the offset option via the offset of the model’s sides
    Check this detailed document about midsurface too for reference
    https://certification.altairuniversity.com/pluginfile.php/17356/mod_resource/content/1/2.4 Generating a Midsurface_2017_updated.pdf
    Altair Employee
    OP
    Hi Roy Duan
    Hi Pranav Hari,
    Could you please sent me the document you mentioned by attachment? I cannot open the link you provided.
    Roy
    User: "Pranav Hari"
    Hi Roy Duan
    Please register to the learning and certification program of Altair university https://certification.altairuniversity.com/. You can get this document from there
    Also refer to the learning library where we have many videos on mid-surface extraction https://altairuniversity.com/learning-library/
    Thanks
