1 - 5 of
51
Hi Thomas,
the material 'error' ins't a error. It is not clear handled at the 'old' error checker.
Please use the new one, at Menu Tools->Model Checker->LS Dyna.
It looks like a error inside of a *sectionbeam property. Maybe you have referenced to a cross section, which doesn't exists.
It happens if you are creating a new *sectionbeam and don't edit the card. Check if there is a beamsec of 0 !?
Regards,
Mario
Hi,
Go to Utility tab with LsDyna profile
There is a tool 'Error Check' that can verify your model before test run
It will guide you to debug some things
