Visualization of elements surfaces sets
rem_rem
rem_rem New Altair Community Member
edited October 2020 in Community Q&A
Hello,
I would like to have a slight different display of surface set, as you can see this elements set is quite huge and solid (grey) almost as element .
I remember from previous versions (or different configuration of display),  i could visualize only small and thin triangles indicating that the element was apart from a set.  I let you imagine how heavy the screen display can be with assembly and/or multitude of sets.
Not sure that this could be depending of the set definition itself, imported from the deck.
It is located as group display under the Entity State item but not in the model item.
Thank you
Answers
  • Sanjay Nainani_20973
    Sanjay Nainani_20973 New Altair Community Member
    edited February 2018
    Hello,
    You can change the color of the contact surfaces but you cannot change how they appear. It does not depend on the set. This is how HM visualises the surface sets and this cannot be changed.
    Thankyou
Welcome!
Welcome!
