I would like to have a slight different display of surface set, as you can see this elements set is quite huge and solid (grey) almost as element .
I remember from previous versions (or different configuration of display), i could visualize only small and thin triangles indicating that the element was apart from a set. I let you imagine how heavy the screen display can be with assembly and/or multitude of sets.
Not sure that this could be depending of the set definition itself, imported from the deck.
It is located as group display under the Entity State item but not in the model item.
Thank you
