Problem with the creation of an isotropic antenna.
User: "Student_21133"
Altair Community Member
Updated by Student_21133
Hello,
I have a problem with the creation of an isotropic antenna.
Feko does not have a native isotropic antenna model, so I created the attached file ("Isotropic Antenna.txt" with a ".ffe" extension) which defines a far field antenna radiating everywhere:
- Re(Etheta) = 1
- Im(Etheta) = 0
- Re(Ephi) = 1
- Im(Ephi) = 0
I was waiting for a perfect spherical radiating diagram, but when I make this antenna radiating by launching the Feko solver, I obtain the attached images : a magnitude artefact at theta=0 for Etheta and Ephi, and an ugly result for the total electric field.
Would anyone have any thought about this ?
Thnak you in advance.
1 - 2 of 21
    User: "Torben Voigt"
    Altair Employee
    Accepted Answer
    Updated by Torben Voigt
    Hi @Student ,
    This is a problem of the display. Feko sees tiny differences and wants to show them. You can simply set the Individual Range to e.g. 1.41 - 1.42 and you should have a smooth image:
    Best regards,
    Torben
    OP
    Thank you very much for your answer.
    It works well and I now have a smooth image.
    But I still find it strange that Feko computes a variable total field value while having the same Etheta and Ephi in any direction as input data.
    Thank you again.
