Get Tensor Value from QueryControl
Hey Guys,
i have recently been trying to get the stress tensor out of hyperview. I can get a query but I can not find the right option to query the tensor.
so thats what I found on the help:
poIQueryCtrl SetQuery
| Node Based | node.id node.pool node.rsys node.asys node.coords component.id component.pool component.name component.color misc.load misc.sim misc.model |
| Element Based | element.id element.pool element.config element.connectivity element.normal element.centroid component.id component.pool component.name component.color misc.load misc.sim misc.model |
| Part Based | component.id component.pool component.name component.color misc.load misc.sim misc.model |
| System Based | system.id system.pool system.type system.origin system.x-axis system.y-axis system.z-axis |
| Result Based | contour.value result.complex_value_M/P result.complex_value_R/I result.value |
But no tensor /emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
Any suggestions ?
Thanks in advance
Hello Guys,
Adding to the conversation, I wanted to write tensor direction and the layer it is probed (lets say for a shell element) to a text file using TCL. Can anyone please let me know how to write the tensor data (vector, layer etc.) in a text file, it will be a great help.
Thanks in advance,
found it out myself:
you have to plot the tensor like the contour, then tensor.value is available.
Not so good documentation though...
